My zeds going in for some paint next week, both bumpers and a few minor things here and there. But also the rear hatch is getting looked at as there is a tiny bubble in one of the bottom corners. So the rear window is coming out, bit nervous as it's blue tint so hard to replace if it breaks, so fingers crossed!
I asked if there was anything I needed to supply for that, and the shop said no....I'm wondering though, whats required to fit the glass back in afterwards? Is there anything I should be thinking about?
Normally you would replace the 90372-32P00 moulding (item 90332 in diagram below) as it is usually damaged
cutting the seal to remove the glass (or is faded anyway).
https://jp-carparts.com/nissan/partlist.php?maker=nissan&type=132&fig=900*&part=9037232P00&page=1
The top corner trim clips 90335M and 90336M and the upper trim 90331 (see diagram) can be saved.
This is the FSM for the rear glass fixing etc. Make sure they keep (take care of) the two spacers 90714 and 90714A.
BF-48.pdf
Edited by AndrewG
Oddly enough just remembered I have a new pair of the corner moudlings lying about, bought as part of some crackpot scheme I had for my old shitbox I imagine....at least I can put them to some worthwhile use now!
