inlet cam pulley wheels
anyone ever had problems torqueing the 19mm bolts through the centre of the inlet cams for the pulley wheels as when i tightened mine 2 day i heard like a click like something breaking behind the pulley wheels.......so i stripped the belt off again, pulled off the wheels and everything looked ok.....any ideas guys
cheers john crisp
oops i forgot to mention, i have only nipped the bolts up with a small bar and put the belt on and timed it all no probs, the tensioner all tight etc and i thought it would be easier to torque the 4 cam pulleys with the belt on bu still jamming the pulley wheels with a screwdriver, the sound was like something breaking but the turns no probs.
Cheers John Crisp
Put the gears back on, torqued the bolts, refitted the belts last night, all appears ok, i just hope i havent broke anything inside the rocker cover, but i dont think so as the cam came off and went on no probs, so i am on the build again but its scarey when u hear a noise and dont know what it is.
Cheers John Crisp
