ABS fault
My ABS light is on constantly, ran through the diagnostics in the service manual and it seems fine except the power to the control unit.
With the ignition on, pin 1 should get battery voltage, but I'm only getting about 6V. I measured the battery voltage as 12.5V.
Anyone got any ideas what could cause that?
Gaz, Ah is that a thing? Could be the connector to the reservoir, I changed the master cylinder earlier in the year
Andrew, was pin 1 to ground. I tried a few different points near the control unit, got about the same for all. Will try again though
Ah, the 6v must have been a ground loop....the fuse had blown, I didn't realise it was fed by the 'eps/hicas' fuse in the footwell, I thought it was under the bonnet. Guess that's for the actuator.
Thanks for the replies anyway!
