levyashin57 Posted October 28, 2019 Share Posted October 28, 2019 My 300zx indicators have stopped working, I've had a mobile car electrician have a look. He found all light/bulbs were fine????? Any one ever had this problem or could help point me in the right direction solving this. Quote Link to comment Share on other sites More sharing options...
Gaz 300 Posted October 28, 2019 Share Posted October 28, 2019 Does the hazards work? https://www.300zx.co.uk/forums/showthread.php?134451-Indicators-not-working&highlight=indicators+stopped Quote Link to comment Share on other sites More sharing options...
levyashin57 Posted October 28, 2019 Author Share Posted October 28, 2019 Does the hazards work? https://www.300zx.co.uk/forums/showthread.php?134451-Indicators-not-working&highlight=indicators+stopped Yes mate hazards work Quote Link to comment Share on other sites More sharing options...
t.mogsy Posted October 28, 2019 Share Posted October 28, 2019 I've had this problem. The screws holding the hazard switch weren't screwed on tight enough or maybe they were too tight, cant remember now but worth a try. Quote Link to comment Share on other sites More sharing options...
Gaz 300 Posted October 28, 2019 Share Posted October 28, 2019 Yes mate hazards work Did you read this thread and what Tom has said. https://www.300zx.co.uk/forums/showthread.php?134451-Indicators-not-working&highlight=indicators+stopped Quote Link to comment Share on other sites More sharing options...
levyashin57 Posted October 28, 2019 Author Share Posted October 28, 2019 I've had this problem. The screws holding the hazard switch weren't screwed on tight enough or maybe they were too tight, cant remember now but worth a try. strange one all lights are working an all bulbs ok???? thought it might be some thing like the stick??? just frustrating cause I brought it to use Quote Link to comment Share on other sites More sharing options...
Gaz 300 Posted October 28, 2019 Share Posted October 28, 2019 https://www.300zx.co.uk/forums/showthread.php?134451-Indicators-not-working&highlight=indicators+stopped Quote Link to comment Share on other sites More sharing options...
levyashin57 Posted October 28, 2019 Author Share Posted October 28, 2019 https://www.300zx.co.uk/forums/showthread.php?134451-Indicators-not-working&highlight=indicators+stopped many thanks will give it a go in the morn Quote Link to comment Share on other sites More sharing options...
Joely P Posted October 29, 2019 Share Posted October 29, 2019 This is a common problem with the hazard switch not fully returning to its ‘off’ detent, which inhibits the indicators. It often doesn’t look like anything is wrong and just needs a slight wiggle back towards the driver. It’s usually caused by the hazard switch mounting point inside the pod failing, causing the switch to track in and out at a slightly misaligned angle, getting stuck in its slot. It’s an easy fix with either a brand new pod or a repair kit. Quote Link to comment Share on other sites More sharing options...
Recommended Posts
