Air Con Line
Hi Guys,
I have searched everywhere but can't seem to find anywhere to get the high pressure air con line that runs from the firewall to the recevier drier, the american ones (concept Z etc) are for left hand drive and are different (unless im mistaken ?), so does anyone know where I can get one for sensible money ?
Thanks,
Olly.
you maybe able to get a aircon specialist to make one for you. it will prob be the easiest option looking on jp parts, it docent look like any of the pipe work is available from nissan
Nah I think it's leaking right near the high pressure connector next to the battery as the gas sniffer is picking up a leak there and previous owner has put some tape around it there.
if it is a small pin prick hole try cutting it out and rejoining with a 8 mm compression joiner, it worked for me and was still holding after 2 years. just check that it is 8 not 10 mm it`s been a few years since i did anything on a z.
a good aircon specialist should be able to repair it, but you will need to replace the drier as that will have moister in it from the system being open
Much easier said than done Kev !!
i have a guy local to me who does aircon repairs on all manor of stuff, he can repair or make up new pipework.
