Fuel gauge intermittent on z32 tt
My fuel gauge is off when low with gas light ? it’s at half tank when full it’s read accurate. I’m thinking it’s the fuel sending unit, i know that the fuel pump is different from the n/a version. But my question is are the fuel sending unit different as well or they share the same part? If anyone know where I can purchase them that will be much help thanks!
If I understand correctly, it never goes above half way, as it ever?
Take the needle off and position yourself at just above the full mark, when you’ve filled pretty much to the brim that is.
The highest it go is full with full tank and the lowest it will go is half when I get my low fuel light.
And does it move steadily down as you go through a full tank, it is moving through only 50% of normal travel.
Yes sir it only goes from to full to half a tank even though the gas light comes doesn’t go any lower
Once the thermistor is no longer immersed in fuel, this triggers the low fuel light, so we know that’s working.
It’s the inaccurate needle position or reading, I’d be taking the cluster out initially, perhaps manually travelling the needle, this is where having a spare is very helpful, you don’t know what’s been happening before your ownership?
