protoj · Tuesday at 18:48 2 days
Hi guys.
I'm replacing the P/S hard lines from the front flexi's under the car to the back "splitter" before the rear rack , can you tell me what size of union is used? Guessing its 3/8" pipe? Looks like
4 male unions I need.
Cheers Darren
