Change engine and tranny conversion auto to manuell.
Hello all.
I'am planing to change my engine and at same time a tranny con. What is the best way to do it? If possible i will change both at once. It means the tranny should be mounted to the engine. Is it space and clearance enough on the Z?
Thx a lot.
Refit the engine and then offer up the gearbox after.
Jeff
Welcome to the club
2004 BMW Z4 30i
1991 Nissan 300zx TT Project
1997 Jaguar XK8 Scraped ☹️
If you are doing it without a lift, then it can be easier to do the engine and gearbox in one, but you'll need to get the front end up on ramps to give enough clearance. Both options work, just depends how confident you are at lifting the gearbox into place lying on your back under the car.
Two MAFs can be used with a Selin translator. Is that what you are using?
https://www.specialtyz.com/selin-design-maf-translator-elbow-kit.html.html
Using BOV's with MAFs is not a good idea. This link explains why:
http://www.twinturbo.net/nissan/300zx/forums/general/view/2421113/I-do-not-recommend-blow-off-valves-on-the-Z.html
Yes, using the Selin. Will also use the BOV`s as recirc BOV`s. I take this ones because they are adjustable.
