'91 Polished Plenum, Throttle Bodies
For sale, '91 TT Upper intake assembly comprising polished plenum (intake manifold collector), cleaned throttle bodies and coupling shaft, cleaned and tested AAIV assembly, tested TPS, new Z-Centre gasket set (which cost £76) and ancillary pneumatic connectors/valves fitted to the smaller plenum apertures. As shown the throttle body coolant pipes have been removed from the plenum, but currently not those on the throttle bodies. Only the upper half of the plenum has been polished, with the exception of (the difficult to get at) central collector region which, together with the lower half of the plenum, has only been cleaned. The innards of the plenum have been brushed, treated with throttle body cleaner and thoroughly orinsed out. The throttle bodies have been cleaned, but (other than the part of the venturi) not polished. In addition there is a new set of throttle body/plenum Allen-keyed bolts to replace the originals and all of the other used bolts from the assembly are available. I had planned to fit this hardware after all the effort, but a change of plans means the original outfit remains under the bonnet. I would prefer to sell the whole (dismantled) assembly as a single lot rather than as individual piece parts. I could rebuild the assembly if required, but to reduce maintenance (i.e. polishing) the bare metal should really be treated before installation.
£200. Any questions or more detail, please pm me. Thank you.
Edited by tandyn300
