window washer
Front window washers stopped working yesterday. Piddles slowly from left one while right one seems blocked/broken
Can hear the motor buzzing when I press the washer button.
Rear window washer works fine.
Any clues
Open the bonet and disconnect the pipes from the washer nozels. Turn on the washers and if there enough water coming out means the nozels are buggered and need replacing. £7 odd from Nissan per side.
Stuart
Try blowing them through (backwards) with an airline or perhaps footpump.
Had same problem with mine. Found a decomposed Blue bottle in the line. fook knows how it got there. used a wire coat hanger and hey presto. Check inside the jets too.
Oh and while you have your jets out, please don't be tempted to buy blue neon lights for them :D
Replace the jets??? No need - do you replace your sink when the plug hoole gets blocked? LOL
Just find some fine wire and push it backwards through the jet with the hose off the back - ta daaahhh!!!!
CheerZ,
Andy
