Hi guys i have sorted out the issue with the damp in the car(targa pipe pulled out on drivers side)At the fuse box, but i have a brown relay and a blue relay and i dont know if they are working,can i use a battery charger or multimeter to check if they are bad,any info would be great.Thanks guys and gals
You can check them with a fused +12v source (battery) and a multimeter set to continuity testing. These
pages from the FSM show the standard relays, their functions and connections:
ย
el-5-6.pdf
ย
Before you buy any of them ask on here first as you may be able to get working s/h ones. Their
part#'s should be printed/stamped on the upper body of the relay.
