Fronts are a good fitment, rears will need arch work depending on what tyres you go for. If you want to go for the silly stretched look then you may get away with it, but under normal correct tyre fitment and I'd advise a 285 width on those, you'll need to pull the arches.
For a 10" wheel you want around a 35-40 offset ideally for the rear.
The think is I was thinking of running 8.5j all round. Engine is stock and it's my daily, probably squeeze some 245/35/18 on there
