HICAS Hose from Solenoid to PAS pump
Help please in locating a spare HICAS hose which links the solenoid to the rear chamber of the PAS pump. This high pressure item is fitted with banjo type hydraulic connectors and is also one of the components made redundant for HICAS deletion. Thank you. Ray
It appears my subs have run out, so whilst you can PM me and Iโ€™ve read it, I cannot reply. Need to sort that out really.
  • 4 weeks later...
Problem solved.
Sourced one from Z1. I do have the ends (FOC) should anyone wish to use them as a core trade-in.
