- Adjust your preference.
- Select Site settings.
Safari (iOS 16.4+)
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
Firefox (Android)
- Tap Notifications.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
300's not running correctly... whilst 90% of the time it drives lovely, if left to idle sometimes (quite randomly) the revs can blip then drop down and try to stall, tiny rev and it stabilises again.
Sometims under boost (say 1500-2000rpm) cruising in a higher gear you will feel the occasional mis.
When going flat out it behaves perfectly under full boost, and will rev-out fine in 1st/2nd, but in 3rd once it gets to 5500 or so it hits a brick wall.
So it's not a boost leak, I think a coilpack or PTU is a possibility, and failing that an injector/connection. Given it's very intermittent how do I troubleshoot to find out or is it a case of suck-it-and-see with replacement units?
