Instrument cluster removal
Ive got a slight problem with removing the cluster. Ive removed all of the dash around it and all the necessaries and all I need to do now is remove the connectors from it. But... when everything is removed theres a connector on either side of the cluster, on the top, for the warning light connector... Now how do you remove this? If I could remove this it would be no problem to remove the others, only these 2 have no slack on the cable and I cant get behind it very easily.
Thanks in anticipation
Clarkey
thanks, got it off in the end with a bit of brute force, unfortunatly thats the same thing which broke the speedo :(
Unclip them and then push off backwards whats left of the clip.
Stuart
