PCV thread size
As above, I shall be deleting my PCV valves and blocking them off, then running both passenger side rear rocker cover breathers into a catch can,
At the front I shall be blocking the intake breathers off also,
Anyhow I digress , what is the thread size of the standard PCV ,so I can order the correct bungs.
Can anyone help ??
Ta
Sayers
hmmm, im seeing 1/4 NPT elsewhere.
Thoughts
BSPT is the common tapered thread type used in Japan. You will need to use thread sealant (as the factory did).
The difference between NPT and BSPT are the thread angles (angle across the flanks of threads). An NPT male will fit
into a BSPT fitting and vice versa but they will not seal without a sealant.
