Removing a Protected fuel pipe
i need to remove the protected fuel pipe between cyl 5 and 6 see pic. disconnect battery, remove fuel pump fuse, remove pipe.
is that about it?
Rich
Remove fuel pump relay and crank the engine. There'll still be a bit of pressure there, but it should reduce it. Get some rags around it too to soak any up.
As Si said crank it for a few seconds to reduce pressure and have a rag over it when you pull it off, you don't want fuel in your eyes trust me.
Thanks guys, going to try it out next few days.
Regards
Rich
Sorry for delay, not been well...again..and again...
