Auto to manual conversion wireing
Any one got a write up with photos on the wireing for the gearbox from the plug under the bonnet did have it but can't find it now
Hi Andrew that's asking me for a password
Actually very simple, but do not change the loom from the alternator to the gearbox, what you need to do on the alternator loom side is identify the inhibitor switch pair and bridge them. Identify the speed sensor cables and recouple them ( normally green ) and then the reverse lights cable from the gearbox needs extending up to the connectors behind the drivers headlight.
Finally and not completely required, the neutral switch, take it from the gearbox to the ecu and connect to pin 44 and to earth, sure I did a tech thread for this years ago, will see if I can find it.
Jeff
