protoj · 28 minutes ago 28 min
Hi I,ve found out one of the fuses in front of the Driver under the bonnet, a line of 5 or 6, Has blown, its the one for the fuel pump, its a FLN-30. Does any one know where i can get them from, apart from USA and China...
