Ebc
So seemingly my blitz ebc has packed up. It's an older style one with small knobs each side and the display in the middle. I want a direct replacement with the controller able to manage 1.5. Bar. Can anyone advise pls. I do not want to be cutting the loom etc etc again.
Does it still power up? I would check there is not another problem first, when my recirc`s let go ( weak springs ) the boost dropped off just like the controller was not working, disconnect the controller pipe and go for a test drive, be careful no need to go mad jusy see if the boost has come back or not, will tell you if it is the controller or not.
Note: If the stock boost solenoids are still plumbed in a faulty det sensor circuit will drop boost off too
Jeff
Hi Jeff, the issue I have is that the car was mapped last year at 1.2 bar of boost, then parked up for the winter, upon digging the car out this summer it was found that it would not boost above an indicated .8 of a bar, So the controller pipe was disconnected and the blowers tested carefully, they were found to spool without problem, so as an interim I fitted a manual boost controller, this " worked fine" however I need to be able to properly regulate the boost via an Ebc. My initial thoughts are that the Ebc solenoid is goosed, any ideas on a direct replacement ? or how I can test the Solenoid for function??
Have you a pic of the solenoid? I have a spare blitz solenoid of a sister model
