What recaros where optional? Sr3's?
Title pretty much sums it up
Sent fra min HUAWEI VNS-L31 via Tapatalk
  • Replies 26
  • Views 3.3k
Yep speeds as fitted to zebedee
Yours aren't Recaro Speeds ;)
SR-3. Identical to Speed other than the "shoulder spikes".
Two different trims; confetti or navy/blue. They weren't optional as such, but came as part of a couple of trim levels.
Enlighten me ?
What he said ^^^ :)
Okay, well I'll need to get a set in black leather to match my rear seats. Those stock seats aren't very good for trackdays and general hooning [emoji14]
The sr3s are great, getting the correct rails can be tricky and most seats will be in need of a rebuild these days.
Very comfortable indeed, but a word of warning - getting in and out of them in a Z really sucks.
FYI there's a style of bride rails that fit, fitted them myself. Though I did have to to space the seat up a bit to stop the slider bar hitting the seat
Ha ha yes they are but i still put myself though it even with my knackered knees
  • 2 months later...
Bumping this, you say they are a pain to get in and out of, are they lower than the stock seats? I'm contemplating getting a smaller steering wheel because it hits my thighs but if the recaros are lower I might get away with it
Depends on the rail used to mount them. I have the factory Recaro rails on mine and they do sit lower than the standard seats. I have absolutely no issues with the wheel being close to my thighs whilst sat in the Recaros.
They're only a pain to get in and out of due to the bolsters (both upper and lower) being far more pronounced than the stock Z32 seats.
Great. I can live with that, it's not like it's my daily driver. And I've found it helps to run the seat back before you get out to make it easier to get in and out of with those types of seats
Also, and only a minor inconvenience, they're really crammed in there. The adjustment knob is difficult to access and they block the arm rest from opening fully without a bit of persuasion.
Mine don't block my armrest at all, Jay.
Probably because it's a two seater I guess.
As long as it keeps me in place when I'm going fast I'm good [emoji16]
As others have said they are noticeably lower.
I've got a lwb and I don't think the seats are fouling my arm rest opening, doesn't ring a bell anyway! But then I couldn't tell you the exact model of seats I've got, look the same to my eye though!
But yes getting to the adjustment knob is a pain, have to remember to make sure it's alright before I set off! Also where my drivers side bolster is a bit worn it sticks out and touches the door, passengers side doesn't do it. I'm hoping Mondo you'll be able to work some magic when you do my interior on the GB! Magic or buying new foam is fine, I'm not fussy :-P
Oh and I also can't tilt the seat forward fully unless it's pushed back, so they are a bit of a tight fit
What about the seat rails? I can only seem to find bride seat rails online.....
They're rare enough, but Japan is definitely the best place to look. Yahoo! and Croooober in particular.
You can't buy new anymore so you'll have to play the waiting game if you want original rails
Don't need original as long as it fits the car, if there are any. I see plenty rails when searching yahoo Japan for "z32 recaro", but not for the speed, only the SR series, but perhaps they fit the speed also?
Yes, they're almost identical seats.
