Turbo coolant delete
Ok, so I pulled the engine out due to ongoing maintenance and noticed this....
Am I right in thinking the coolant line has been blocked off?
If so, for what reason?
Should the pipe with the bolt jubilee clipped in the end be connected to the open turbo pipe?
If a hard pipe was leaking I take it the coolant flows down into the turbo from the blanked pipe, not up from the turbo?
