JDM S1 Left Hand Instrument Pod
Help please to locate an available left hand instrument pod for a '91JDM TT. In fact, I only need the housing. I managed to break out the Hazard Warning Switch mounting screw holes, which are used to retain and position both the switch and the small retaining plate used to anchor the hook features at the top of the pod front panel. What a prat.
brand new there 40 quid or u can repair with self tappers or i did mine with fibre glass
OK , Thanks for that. Plan B or C is to build up the breaks with resin as you suggest. I'm thinking of spraying the screws in silicon lubricant (as a freeing agent), locating them in position in the housing and then build up the resin around the exposed shafts of the screws in-situ: Wait for it to set and keeping my fingers crossed, extract the screws!! So much for the theory......
