Performance parts for sale
Hi All.
So I've got to get over a few hurdles before I can get J299 back on the road, so unfortunately some of my upgrade parts are going to have to go.
Most of the items were purchased from the forum over the couple of years and i'm just trying to get my money back.
All prices include standard signed delivery, but insurance to the value of goods will be added at cost if required.
Lightened Billet Unorthodox Racing Pulley and Crank pulley Set with New drive belts £200.00 Price Dropped!
Side Mount Intercoolers 2" Pipework New Unused £160.00
Popular aftermarket upgrade SMICS
Specifications:
About this product:
MPN: ZZ02370
FOR: Nissan 300ZX/ Fits 300ZX Z32 turbo models
FEATURES:
Intercoolers are an excellent way of safely increasing BHP ​​
​Tube & fin style intercooler cores (8x15x3") ​​
​2" inlet and outlets ​​
​TIG welded ​​
​1050cfm @ 0.5psi drop ​​
​Capable of handling up to 600bhp.
5.5 kg Lightened Flywheel (purchased from a forum member (reportedly good for 500 fwhp) £100.00 Price Dropped!
Zedworld Chipped ECU £90.00 SOLD
Auto TT engine bare block and heads . (Leak down test reported some valve work required, block compression good) £175.00 Collection only or Delivery available at extra cost.
Auto Tubs (some play so would benefit rebuild) £80, Price dropped! Free if purchased with engine.
Edited by SteveE
Information added
Hi mate - are the side mounts larger than stock? Any
Damage? And what else would I need to fit them?
They are quite a bit larger than stock, and require some modifications to make them fit.
Let me hunt for some pictures i have
Don't need anything else to fit them
Can't find them comparison but here are mine (similar product) fitted 4b8424d67d1822907357539752f7f499.jpg
Edited by Alic
Hi will, They have been taken out of the original boxes and one unpacked for the purposes of the photo only, brand new and no damage.
They are a definite improvement over stock allowing more air to be cycled to the intake manifold and manage the cooling of the Turbo gasses.
As Alic has said (although i didn't know as not fitted before) may appear to need some work to install.
Edited by SteveE
Already shown Will, but for anyone elses interest here are the stock and these side by side (potato quality)
Edited by Alic
Interested in the ECU, any more details?
Hi Mate
The Zedworld ECU is for Twin Turbo Manual and I believe is an upgraded 16bit eprom allowing for ease of removal and programming.
This particular Ecu came from a highly respected member of this forum and if you don't know Zedworld was the place to go if you wanted your Zed kept in Tip Top shape, the original Zedworld owner (JefTT) selfishly chose to take himself off to the Sun in Portugal Lol! but the business itself still continues today with resident engine Guru Jimmer.
The information below is taken form the original Zedworld website.
"Performance chips are available with different specs designed and written to suit particular engine stage upgrade, knowledge of your engine tune stage is important to ensure a successful and reliable package is ordered
Ecu performance upgrades are essentially a re-written eprom that fits into the vehicle`s main engine control unit. Manufacturer`s have to make sure the programme they write enables the engine to run in a large variety of states of good or bad tune and needs to include basic drivability for the experienced and no so experienced driver and hence compromise is bound to creep in.
This is where performance written instruction`s allow for better fuelling and higher turbo boost levels, it is to be remembered thought that an engine running such a chip may need to be kept in a tighter level of service to not only make the best of the conversion but to safeguard the engine against damage, this is why prior to making a chip upgrade Zedworld advise a pre-service and inspection to assess tune state, improve standard running essential to the on going tune work.
#An eprom upgrade is the able to run alone, but further upgrades in intake and exhausts can give extra power release, a staged upgrade will provide reliable and consistent results and also provide normal service and maintenance codes which enable the Nissan service "Consult" test equipment to access fault codes etc for future serving. "
I have posted a picture of the ECU, it has been dry stored in the same packaging as I received it, I hope this helps.
Edited by SteveE
Inter cooler specs.
Specifications:
About this product:
MPN: ZZ02370
FEATURES:
​TIG welded ​​
Edited by SteveE
