protoj ·
Got a full set of spat for a 2+2.
They look to be in good condition but need to remove them to be 100% sure that they are good.
Will include all the fitting to go with them.
Will add a picture tomorrow at some point after I've done a few other work related tasks.
The price is for all 4 posted via signed for and tracked courier.
Collection tion is always welcome and may even make you a cuppa tea :)
If there is any other parts you are after then just ask as may well have it as long as it's not engine related.
