Super Size Brembo 6 piston front setup
Hi guys, as stated in my build thread, I'm going to Plan B, so Plan A is up for sale:yes:
I'm selling a newly refurbished pair of Brembo SRT8 6 Piston calipers, (new seals, stainless bleed valves, hardware (pad springs+bolts) powdercoat, heat resistant silver "Brembo" logos and brake pads. These are hard to source over here as they're mostly on the US market. A scabby pair (in need of refurb) retail around the $800 mark, then you have shipping etc on top, plus the cost of coating and hardware. Also included are the adapter brackets and necessary bolts washers etc, which are a straight fit onto our hubs. For £1300 you get 355mm drilled and grooved discs included, you can source your own if you prefer which will reduce the price by £200, this kit is fitted to my car but has never been used (black rust-proof paint still on discs).
I would like to add that the fitment of these brakes are dependant on a minimum internal wheel diameter of no less than 450mm. Some 18's will fit (TE37's Nismo LMGT's etc) some will not (my Veilsides). Again most 19's should also fit over them but check before you buy. Brake lines are not included as I need my ones to fit my new setup to. They're the basic Banjo style found on Evo's etc.
Edited by Richie K
  • Replies 27
  • Views 1.5k
