Hello does any body have one please.
I'm looking for the Screw cover that fits on the front side lights. Should be about 10cm x 1cm in size.
It's for the drivers side but I think they are same both sides.
Trying to avoid buying whole light unit.
You're unlikely to find one as they only tend to be removed....when they're actually broken. They're a bitch to take out of a lens. Personally, I'd go and buy yourself a couple of new lenses from Z1, they're not really expensive and they freshen up the front of the car nicely.
https://www.z1motorsports.com/front-lights/nissan/oem-left-fog-light-lens-p-663.html
https://www.z1motorsports.com/front-lights/nissan/oem-right-fog-light-lens-p-661.html
All you have to do is to swap out the reflectors from yours.
Some models had the side lights in them too
All JDM models did. UK models have a completely different uni. USDM models use the same lens as JDM, but don't have the reflector cut to accept sidelights.
I changed my JDM fogs last year & they had side lights in them.
I will have a look in the garage to see if I still have them.
If you have that would be great other wise I may need to get a new lense.
For clarity, this is the part you are after? They are handed for each side, so you will need the drivers side cover.
[ATTACH=CONFIG]103718[/ATTACH]
Thank you posting the image
Thanks for the info
Hi Lou,
Had a good look in the garage but sorry no luck.
I must have thrown those bits away!
Art
Hi Lou,
Art
Thanks for looking and posting back. Should have one coming from scotty.
Lou
You will, I'll post it out tomorrow special delivery, should be with you Wednesday.
Appreciate your help scotty
Thank you
Received The lense this morning.
Thank you
Lou
