Brembo front big brake kit - bolt on and complete.
I've recently changed my front brakes to this setup, but I'm now going to be changing them again so this kit is up for grabs.
The Brembo calipers are from a Nissan Sentra Spec-V and, unlike the 350Z Brembos, these use a 12mm bolt so they bolt directly to the Z32 hub with no modifications whatsoever. :)
I very recently had the calipers thoroughly cleaned, blasted and then painted in Candy Red. I replaced the Brembo decals as well. The pistons are in superb condition and I replaced all the seals before fitting them to my Zed last week. I'll fit a brand new set of stainless steel bleed nipples as well.
The discs are 320mm in diameter and I think 28mm thick. The discs are lip-free, although they had been stood for quite a while before I fitted them - I cleaned them up front and back before fitting, but they may well benefit from a skim.
The brake lines are brand new from HEL and have only been fitted for 5 days. Since being fitted on November 22nd, this kit has covered less than 20 miles.
So you get 2 freshly painted and rebuilt Brembo calipers, 2 discs, 2 sets of pads, 4 new stainless bleed nipples, all the associated clips and pins, 2 HEL brake lines - everything you need to bolt these onto your Zed and be on your way. :)
Why am I changing them? They look a little lost behind my 19s so, for purely aesthetic reasons, I feel I need something a little bigger. That's all.
I'm taking a huge hit on these but that's just my bad luck. Looking for £475 including UK mainland delivery.
Please be aware that this kit won't be off the car for a couple of weeks so, if someone wanted to secure everything with a deposit, that's absolutely fine.
The calipers before they were fitted. Freshly painted and new Brembo decals applied. :)
Starting to think I should have bought these instead now mate lol
Someone somewhere will get a bargain with these....
If it wasn't for the fact I bought a set recently I would have snapped these up too.
Coulda shoulda woulda... :lol:
