Installing a boost controller, remove stock restrictors or not??
I was gonna install my forge unos bc today but a lack of connectors and wrong size vacuum hose put an early end to that. Anyways I followed the guide on Z32 wiki and it said after taking of the wastegate hoses to follow them back towards the end and remove the stock boost restrictor thats in the line, but getting to them seems physically impossible(perhaps from underneath the engine?).
And then I looked at robos z32 page and it didn't mention anything about removing the stock jets, I searched on here too and found an install thread that said the same; just tee the wastegate hoses and plug the remaining hole and off you go... So is that the way to go?
you can leave the stock restrictors in place.
remove any additional restrictors/boostjets though (if present).
Cool, thanks. No I don't have any boost jets installed, all stock boost system
Hi Spiff is your car chipped? If it is then theres a good chance there are "welding tips" in your lines. Look for 2 jubilee clips on the small pipes that run past your throttle bodies.
