Brake Master cylinder brace
Hi all, After getting positive feed back on the my Brake Master cylinder brace out of aluminum, Which I will in clued a stainless blot/nut and two longer M6 stainless bolt/washer?
These are machined out of a solid aluminum on a small hobby milling machine which you can polish / paint / anodize to meat your needs
If your interested if you go to the :- Classified Listings/[Wanted] : Brake Master cylinder brace
and put your name down so i can work out the amount of aluminum needed.
