Rear lights staying on
Hi as above my Rear lights staying on...My battery has been going flat so I took it out and charged it in my flat for a day or so, now put it back in and all was fine. Just walked past my car a few hours later and noticed rear lights on, so got in car to check to turn then off and everything seems to be off but the lights still on...I have now taken the bulbs out as again the battery is drained and just would start....any ideas please? Thanks Lisa
You haven't knocked the rear fog light on?
If it is an import, they sometimes wire the fog light switch to the rear lights. This can cause them to come on when the rear fog light switch is turned on.......
Have you got front sidelights on as well?
its an import but the fog light is wired separately. Not that I noticed, did have quick look at front and didn't see nothing, plus it makes a noise if front lights on, cant check at mo as I have taken the battery out again and put it back on charge
Front spot light switch also brings on rear side lights.
Jeff
Do you mean the rear brake lights?
If so, check the switch at the brake pedal, could be stuck on.
Not really sure tbh, just top lights which are in the red part of the lights at rear, I will check again once I put battery back in and get someone to check brake lights and jam pedal up and down a bit see if makes any difference, I will also check all the lights on the dash too which I have already but all seem to be off. I'll also check the switch above brake pedal, see if they go off when I disconnect it. Thanks guys will keep you informed:)
And finally the little black box behind the rear drivers plastic light panel is the sensor/controller for the rear lights, although normally they wont come on if its rusted out on the board, but worth checking
Hi, so I have now found out that it is a little grommet thing on the brake pedal. Does anyone have one lying about or can I get one from Nissan cheap enough? Thanks
