Wipers and accessories not working
Hi,
New to the forum and after some help with the common accessories relay fault.
Have swapped relay but no luck ? MOT is due.
Looking through the wiring diagram which seems to make sense but I cannot see identification on the plugs which are numbered on the drawing? Anyone ever seen a fuse box layout?
Any help would be really appreciated.
You've swapped out the relay that's a pig to get to, behind the footwell fuse box ?
ย
And what doesn't work, wipers as you say but the left heater pod, mirrors, cig lighter, etc, ?
ย
Welcome to the forum btw :thumbup1:.
Edited by phutumsch
Hi,
Thanks for the reply.
Yes swapped the relay furthest away behind the fuse box, it was not fun ::thumbdown:
It seems everything on the centre consol is dead, I checked for voltage and it looks like the accessories relay isn't closing so very upset swapping it didn't work.
Thank you for you half & advice Replaced the relays as said car booked in for Mot Tuesday You have the Magic touch So cross your fingers mate "Thanks" Diamondlyne
