Hi,
Please listen to the video provided and tell me what you think
[video=youtube_share;W4mZw5UOc60]
I have read it could be the VTC
Is the VTC part of the timing gear or can it be replaced separate?
Thank-you
Chris
sounds like somthing hitting the cambelt cover when was the belt done? if you put your hand on the cover can you feel anything i had a car years ago that sounded just like that the belt was split and was hitting the cam belt cover just an idea
I have removed the cam belt covers, nothing is hitting them, the belt was done 60k ago
ok then does sound like it from what i remember.
sounds like a failed VTC cam gear or failed t-belt tensioner causing slack/play in the t-belt (if you have removed the covers, you should be able to see the tensioner)
if the gear has failed, then you will need to replace it completely.
but check/replace the small VTC springs first (behind the plates on the VTC timing gear) and see if that makes a difference in sound.
Did it sound like this all of a sudden or is there a story behind it ?
Needs doing again then!
I've ordered a new VTC gear, i was driving home at night no problem, the next morning this happens. I treat the car with respect, no revving at cold or daft things like that.
