Air con, cruise control and recirc valves
I'm looking to reinstall all of the above to my zed, so looking for some good used stuff!
With the air con, the ecu is still in place so I don't need that, and if that wasn't removed I presume the core is still in the dash somewhere. But I suppose if someone's got one, I might as well take it just in case. I don't need the receiver/dryer as I will get a new one. I don't know much about the system so not 100% sure what is needed, I was hoping I could find someone who has removed all theirs and just take the lot!
With the cruise control, ecu is still there also, all the buttons present etc. Is it just the pump and clutch switch that I need? Seems to be two brake switches there already, it's an auto conversion though so I suppose the wiring for a clutch switch may not be there. Again, don't know loads about the system so not sure, any pointers appreciated :-)
Not sure what there is to say about the recirc valves!
I live in Wokingham and work in Bath so can collect all around that M4 corridor.
What have you got?!?
I've just been taking cruise and A/C from a car that I've got in the workshop, so I might be able to help with some bits. The car is still here so can see what related parts you need!
Ah that sounds good, shame you're just a touch too far to drive up to! How much would you want for it all?
This may help you:
Cruise Control Installation.pdf
This may help you:
[ATTACH]96121[/ATTACH]
Thanks, yea that's what I've got my information from so far. Seems pretty straight forward, just the difference between auto and manual I'm wondering about
