Speedo doesn't work
After my shell swap my speedo doesn't work. The shell I swapped onto is a 1990. My running gear and engine loom are from a 95 n plate. Only the engine harness was replaced, all the other wiring is original. Bearing in mind the 95 model had electric hicas and the 1990 had hydraulic hicas. The hicas has now been removed. Can anyone tell me how I can check the speed sensor signal from the socket which goes into the back of the speedo. I have a multimeter to test. Any advice or help wold be greatly appreciated. The instrument cluster is from a UK spec car I used to have. The 1990 model was originally fitted with cruise control the 95 model wasn't.
No posts to show
