Window problem
Drivers side window not working. Hot wired the motor and that's working fine, up and down. Switch is activating relay. Opened up relay and contacts are clean but when switched, there is no power going to the motor, either up or down. Any ideas?
Jeff - as usual you have proved that this is the No 1 site for 300's. Just checked the PCB and seen the problem exactly as you described. Thank you.
  • 3 months later...
Got a power window issue help much appreciated. Fitted new amp still no joy, I have power in one wire to amp, power in one wire to motor but no power to switch, power seats all work fine but both windows won't budge and no noise and now power to eith switch, 4 wires to motor and power is in the White / pink one can anybody help"."...
