Pair of 10mm spacers
Hi all
Just looking for a pair of spacers, thinking 10mm. Just to get my front wheels sitting a little further out. Here's how they sit currently:
If you have any laying around, then I'm interested :)
If you're going for 10mm spacers (they'll need to be hubcentric), you'll need longer studs too. What is the width and offset of your front wheels? I think you could get away with 15mm looking at that photo which means you can get bolt-on hubcentrics meaning you won't have to take the studs out.
15mm hubcentrics it is then! :)
I actually can't remember the offset and width. Will whip a wheel off tomorrow or Monday and have a look
They do sit a lot further in than the rears. I'm perfectly happy with the back 2.
Make sure you check first. I'm only going by 'sight'. Check the width and offset and report back. :)
Your rears do look fine, although you could do with a wider tyre.
Will do!
Rear tyres are 265. Wider you say? :biggrin:
Will do!
That's how wide my fronts are! lol
Yeah, I'm guessing you're 9.5" rear in which case, 275 would give you a nice flat tyre wall and make it look a little more beefy. If you're 10" at the rear, then you can go to a 285.
Simon you like the flat walls, not everybody is the same and wants that, a little stretch can be fine and as you well know some tyres have a more rounded shoulder than others which can make arch clearance better such as my Vredesteins that i have on the rear
Maybe - but if you look at the OPs front tyres, they're fairly flat and don't match the profile of the rears - not to mention the space is there for it. So there's more than just a personal preference involved....
Edited by Funkysi
I agree with all you say.
OP check out this thread and please note what Stephen put in post 8, you may want to go to even 20mm hubcentrics.
http://www.300zx.co.uk/forums/showthread.php?182724-15mm-Hubcentric-Spacers-Swap-4-My-25mm-Driftworks-Ones-Please&highlight=15mm+spacers
