Air con pump
Hi, looking for a good Air Con Pump , (Clutch in mine has failed).
If you can help
Text me on 07929159828
Sayers
Iv got one you can have bud but it's a heavy bugger
thanks any idea what postage would cost
it is a series 2 Mark , im also after a set of manual NA uk clocks if you have anything like that in let me know pls
I have Uk Clocks .. and S2 Pump .. they are diff to s1
Hi Mark , you supplied me with the last clocks , I don't know if they are series 1 or two,im changing them out as I want rid of the pulse converter thing, I think I had it converted to take series 1 clocks, if the ones you have are from an NA can I try them for size ? if so drop me a PM with how much you are looking for, for both clocks and pump. ta
ok best to get a picture of the back of the clocks u have installed now .. to see if they are s1 or s2 .. the converter is only for Jap clocks to take it from kph to mph
installing UK clocks will be all you need just need to know the connections
okay ill take a snap on Saturday after it passes its MOT
