Fitting Aluminium Clock Rings
Right guys, just wanted to know from someone that's fitted them before..What adhesive did you use?? Superglue, silicone or something else?? I'm worried that the superglue might damage / stain the surround and I don't want that. I want something that can stick them but is easily removed if I change my mind (which happens a lot:biggrin:)
I used superglue on mine. As the bezel separates from the clock, I wasn't too worried that they'd not be able to come off - quite the opposite as I can always get a bezel if I fancy removing them at a later date....which I might as I am considering going back to a stock steering wheel (I'm probably going mad).
the ones at concept z and z1 doesnt require adhesive ;)
Correct, but I added a dash of glue on mine. They're press-in. Wouldn't want them pop out!
I followed both Si's (Funky + Mondo) and used a drop of superglue at the top and bottom of the rings and they're well attached to the bezel:thumbup1:
