What discs/pads?
My zeds got a really horrible vibration on braking so time for new discs I think. Can't see anything obviously wrong with any of them so I was just gonna get fronts first and then rears if I need them.
I've got the 350 track pack setup on the front, but what discs/pads should I get? EBC? Brembo? Or should I just get OEM from Nissan? Only for street use, I won't be taking it on track.
Thanks!
It could be that the disc is warped, but also check your tension rods as excessive movement in the rubber bush or deterioration can also affect the braking
Ah good shout, I'll check them before I buy anything, thanks
Cheers for this,i also get vibration when braking from say 60 mph plus,plus my brakes lock up.Hence im looking over the winter at replacing them for 350z discs/brembo calipers..il look at tension rods at same time
Couldn't find anything wrong with the tension rods but did find a significant amount of play in the right rear wheel bearing so will do that before anything else, though whether it's enough to cause the fairly severe vibration I've got under braking I'm not sure...
