On the subject of tracking i had the alignment sorted out on Saturday as the car was pulling to the left,the alignment was done last thing Saturday so i took it down the M4 to check,guess what it felt no different.
Sunday went to quick-fit who used the old fashined light set up and the tracking was still out!!!!!
He then set it up and i took it for a spin.Guess what the ****ing thing still pulls.There is some wear on the left wheel inner tyre but i doubt it could cause this.
I need to get this sorted this week does anyone know someone in West London that can help?
Also i've sorted all the wires ready to fit the head unit but no power to the cables.Can someone tell me if there are fuses somewhere that give power to these leads there are in-line fuses but they are fine.
Apart from that i love the car!!!!!!!!!!!!!!!!!
A brake sticking on one side could cause that. Jack the front of the car up and spin the wheels and see how long it takes for them to stop. You may find that the side the car is pulling to, the brake is slightly sticking because the wheel stops quicker when you spin it compaired to the otherside causing the car to pull that way.
Stuart
this problem is caused by your z having an identity problem.
It thinks it's a Ford Modeo:D :D :D
aaaaahhhhhhh run away;)
