Help Needed
Hi all,
I'm having a few problems wih my larm. It's a Laserline 996 V2. Now and then (and getting more often) when I arm my alarm it arms and then gives three short beeps. I know that if I walk away now then the alarm will go off within a couple of minutes.
This is supposed to happen when one of the doors is not shut or the lights are still on etc. But I can't find anything not shut or not on.
Anyone know what these beeps are or does anyone have or know when I can get an instruction manual to look this up ?.
Help needed as my car is unprotected.
Sounds like your ultra sonics are knackered. I have the same problem with my 996, so i just turn them of by pressing the other button on the key fob a couple of seconds after you arm it, this will stop the alarm sounding but you will not have any ultra sonics.
Mine beeps like you said with yours when one of the doors are not shut. It could be simple as one of the door sensors, boot or bonet sensors are not working. Could just be a wire fallen off.
Stuart
Thanks Keith. I will try to turn off the US sensors to see if these are causing the problems. Do you happen to have a manual for this alarm or know wher I can get one ?.
Thanks Stuart. I'll check the wiring to the door boot and bonnet sensors. Although the problem doesn't happen all the time, just now and then. Maybe the contacts just ned cleaning, I'll give em a emery.
Sorry no manuel.
Right I think I've sorted it.
Tried to disarm the US (Ultra Sonic not United States LOL) but they didn't seem to be the problem.
The door switchs on both drivers and passenger side are earthed by the screw that holds them in place. So I removed the screw gave the metal contacts a wipe and no more triple beeps after the alarm sets.
However, this may still be a problem, I'll have to give it a few days to make sure.
Thanks for your suggestions anyways guys.
