Fuel filter spec's
Hi,
Does anyone know the fuel filter flow and filtration spec's?
I'm going to relocate the fuel filter and I'm looking at various different hi flow Syntec billet aluminium filters that range from 30 micron to 80 micron in filtration. As well as 6 to 10 bar of pressure?
Thanks Dan
Hi mate,
Where are you relocating the filter to? You have a shortie so I may be able to give you some tips if you want
Hi Douglas where did you locate your filter to?
I'm not doing any major engine modifications as of yet but want to tidy up the engine bay.
Thanks Dan
Hi dan
Didn't see your reply.
I relocated my fuel filter under the car. On the swb there is a perfect location, it is very similar to many other cars.
I don't have a picture of it fitted but I fitted it in the bottom right corner in this picture between the fuel tank (black pipes) and the fuel lines. You can even use the original bracket if using the Oem. It then gets covered by the plastic pipe guards.
I'll try to send you a link to a guide I found
Thanks Dougal thats very interesting! I will look in to that modification when I do some more works on the underside.
For now I mounted the billet filter in a similar location to Oem bit out of the way of the rear engine bay skin I'm fitting.
