clutch question.
Hi all as per my previous threads my cars been off the road
For several years for an engine swap. This is now done and
Runs ok. The clutch and box were fine. Although in the last
Few months it's been sat the clutch pedal now goes straight
To the floor with no resistance. I've changed the master
Cylinder for a brand new genuine item and a new slave also.
It's bleed up alright as per manual on both nipped. It feels
Like a good clutch but start it up and it's back to square one
Straight down to the floor and can't select any gears. Can't see
Any obvious leaks and everything is tight. Can't find or hear and air leaks
Whilst clutch is being depressed with the engine running or not.
I've repeated the process about 6 times can't get any more air
Out.
Any ideas welcome
The OEM clutch is fairly difficult to bleed. Have you made sure at the Reservior dint run low of fluid when you were doing it? As it not a big Reservior maybe more air got drawn in whilst you were doing it?
Not much help now but it May be worth changing to a 1 piece stainless steel clutch, this also does away with the nipple on the inner wing,
Mine is an auto to manual convert. So it doesn't have the wing top bleed block. This means I have to bleed it from the drain on the slave and is very very difficult to do.
Have you checked the vac booster?
Cheers bigh seems to be the way forward
Everything seems right plenty of fluid . Can't
Understand why it drops off while it's running
With no leaks
Could I make a pipe up to go from the master
to the slave out of standard copper brake pipe???
Is this worth a try ?
