Sump plug washer size
Is anyone able to tell me the dimensions of the copper washer for the dump plug, please? I don't know what to order until I take the sump plug out, but it'll be a bit late then...
Many thanks,
Phill
The bolt is an M12 and the part number from Nissan for the washer is 11026-01M02, any Nissan dealer should have one in stock as they are used on other Nissans too.
NB it is a copper crush washer, so enables a seal by the very nature of its design, do not try and fit a normal washer as you will end up with leaks
Edited by groover
If it's not too late, get yourself a magnetic sump plug, plenty on ebay :cool3:.
Did yours arrive with a steel washer already on it? My Greddy did from ConceptZ and I had to cut the washer off with my dremel as it was leaking even with cold oil!
Yes did come with a washer on and no problem for me, i even got one for the radiator and that came with one as well and not a problem either.
