Checked all round engine bay plugs and replaced (fixed) loose or bad connections
Tested each injector with meter all now reading between 10 and 14 ohms
Checked coil pack plugs with meter.
Checked MAF stalls when unplugged
Although UN related 're set TPS
Checked codes 55 clear.
So far I'm up to about £300. With parts ect .
I can't do anymore as its beyond my knowledge if I took it to a local garage they'd scratch there heads and charge me time. So it need some one with knowledge of these engines . No doubt I will have to travel a fair distance (if she will make the journey)
Could this be a fuel.pump issue? That's the only part I've not tested is the fuel pressure or the fuel regulators ?..
Ok so rough idle still and missing.
Things i have done.
Replaced coil plugs with new
Cleaned out Idle control valve
Replaced all coil packs
Replaced one injector as it was reading 18/20.ohms
Checked all vac hoses for leaks
Checked spark plugs (ok)
Checked battery / alternator (multimeter) 14.4 volts
Checked fuel pump plug connection
