converting rear panel reverse light help needed
the rear panel that says 300zx on it and have 4 light that come on am going to use one side for reverse lights and the other for rear fog lighs. standing at the back of the car what side does a rear fog light have to been on or does it not matter ?
ime sure the drivers side Dan
Is there a "how to" guide on here for this as it's something I'm thinking of doing myself.
Club member no. 779:thumbup1:
yes its off side drivers side bri. its dead simple just snip 2 wires are solder 2 mine is a uk car so all the wiring is there its just snip and solder. also will need a new red bulb for the fog
Or send it to Phutumsch and he will convert it like mine two bright cree lights for reverse in the lower chambers and 2 fogs in the top with the lenses converted to red
i did want to do that but having them each side will be fine for now ian. maybe do that in future
thats a good idea isnt it
Nicely done, I'd be afraid I'd feck up my brand new 99 Spec lights though:no:
see if you can get hold of a second had set of backing sections... should be cheap enough..
I have my original set also, so just take out the lights of that one and try drilling it out?
