stone chip removal
hi when I get my zed repaint I want to remove the stone chip from doors sills an bumper door an sills will be ok to remove with abit of heat being metal any tip for the bumpers thanks
Just do a bit of a search on here... There are several threads about this.
The finish on the bottom half of the bumpers is actually moulded into the bumper skin, so the only options are to either fill it (not recommended) or sand the whole thing flat.
Just be advised that the highest points on the finish are as thick as the rest of the bumper, which means that the lowest points in all the little indentations will be thinner. When you sand it all flat, you're effectively making the entire lower half of the bumper thinner and therefore less sturdy.
:thumbup1:
just read a few thread it seems sanding the only way I think the front going to be the hardest
