Highly modified 94 uk tt manual
Well folks, the day has finally come. After 7 years of epic ownership, the time has come to sell the greatest car ive ever had the pleasure of owning. Reason for sale, kind of backed into a bit of a corner financially, and this is my ticket out. Guts me to have to do this, but ive been putting it off for the last few years. So, here goes.
Ill do another thread and link it here about my Z story, for those that care. But for this thread, ill get down to business.
Car belonged to markzx, a previous member on here and quiet well known at the time of building this Z.
He did all the major work and ive just finished it off how I wanted and kept it maintained.
Phil and blackmoor service station (previously of C&S woods and builder of a good few highly modded Z,s on here) did the major work for mark, and has continued to keep it on top form and looked after it for me.
Car is UK 1994 manual (converted), its series 4 and last of the UK spec with the charcoal grey leather, but no airbags and emmisions rubbish that came on the later spec.
Mileage on the clock is 159000, however the current engine and gearbox has done around 45000, and all suspension parts, bushes etc have been uprated along the way.
Comes with full mot and has just had both rear sills professionally repaired and has new tyres all round ( bridgestone S02).
So that's the base car.
The mods:
Suspension
Blitz springs (lowered 30mm)
Koni Pro Sport ajustable shocks
Full poly bush kit
SPL ajustable front camber arms
SPL ajustable front tie bars
Whiteline ajustable rear camber kit
Hicacs Removed.
Stillen Elliminator bar
Stillen front and rear strut braces
Z1 rear ajustable camber arms
Z1 rear ajustable traction rods
Stillen ajustable front and rear anti roll bars
Brakes & wheels
VRS 2 piece light weight 18"s split rims
8.5" Fronts and 10" Rears.
Bridgestone S02 Rubber all round
Full Nissan Skyline GTR Vspec calipers with
340mm dba discs and ferrodo ds2500 pads.
New brake lines and braided hoses
from master cylinder to calipers.
Blackmagic Brake Brace.
Brand New Master cylinder.
Brand New silicone servo hoses.
Motul rf600 brake fluid
Drive train
OEM 5 speed manual conversion
Mocal Thermo Oil cooler flow valve
Nismo Short shifter and shifter bush kit
RPS max TT organic clutch and fidanza flywheel
Unortherdoex Pully's and belts
Brand New Master cylinders
Brand New Slave cylinder
Brand New braided hydraulic hoses
Brand New Clutch booster
Brand New Silicone Booster Resrvior Hoses
Brand New Clutch Vacuum reserviors
NA Power steering pot and Briaded hoses
Z world lightweight 1 piece prop
Engine
Wesco 89mm forged pistons (now 3.1 ltr)
Eagle forged Conrods
SpecialityZ enlarged baffled sump.
Fuchs titan pro race engine oil
Toga Racing shell and small end Bearings
Bronze Valve stem guides
Solid lifters
Skimed, Polished, Valves recu tand seated and Heads reworked
Mike smith Manifolds
New NA Oil Squrters
Balanced Crank
Brand New Idle control Valve
Brand New Cam Belt tensioner
New Cambelt Pullys
Genuine complete Unortherdox lightweight belt pullys
Lower Plenum polish
Nismo Thermostat
Torga Motorsport high flow oil pump
Brand OEM New waterpump
Nismo 555 injectors
Garrett GT2871RS roller bearing Dual cyclone Turbos
Integral HKS gate valves
Noltech engine mounts
HKS Irridium S40i plugs
Power Enterprize Racing Rad 200% larger than Standard
Greedy Large volume side pod intercoolers
20" Pacet fan
24 row Mocal oil cooler
Mocal Thermo Oil cooler flow valves
Mocal Remote Filter plate
Mocal Remote filter housing
5/8" blue nylon braided oil feeds
Braided Fuel lines
Braided power steering feeds
Smithy's Place hard pipe Rad kit
Smithy's place hard pipe intake kit
Power Enterprize induction Better breathing than the Apexi's that I had
Apexi BOVs
Allunox custom built stainless divorce down pipes
Allunox custom built stainless decat X flow system
with wide band lamber sensor boss
Allunox custom built stainless tail pipes and silencers
Body colour co-ordinated ballance bar, throttle cable,
Cam and cam belt covers
Got rid of all emissions rubbish
Got rid of throttle body preheaters and Plenum hot water system
Polished Plenum & throttle bodies
Polished inlet and outlet water pipes
New Heater matrix
Every Pipe, hose, PCV valve Gasket uncle tom cobbly and all replaced.
Electronics
Series 2 PTU
New wirring loom
new knock sensors
New knock sensor harness
New lambers sensors
New temp sensors
New Idle control switch
Pacett thermal transmition switch for fan
JOHN DIXON chip for above setup
Greedy Profec e-01 Boost controller
Greddy 52mm Boost, Oil Temp, Oil Presure, Exhaust and Water temp gauges
Smiths international 52mm Fuel Air/dent and Clock gauges
All Traffic light Green, Red and white LED Clocks Switch pods and Guages
Interior
Interior is standard, with gray Alcantara
twin clock door pillar pod
Triple centre dash pod
Sound System
Kenwood 1000Watt Amp
Sony bluetooth xplod stereo
Lanzar speakers front and rear inc tweeters
Self amplified sub, all easily loud and clear enough to be heard at motorway speeds with the roof off.
I spoke at lengths with the previous owner and the mechanic and this car was the culmination of many years of experience and Z/other sports car ownership by Mark. The spec list was very carefully researched and chosen to be an everyday porche beater (the words of mark, and back when it was built, that was true, some quick poches out there now like). The engine produces just over 400bhp and similar torque, the boost comes on smooth but hard and pulls really well. Not the most powerful car out there but its built and tuned to last. This spec is capable of running 500bhp+ as plenty of owners on here are doing. But this car has been and will continue to do this for years. And its never missed a beat. I have used the car for what it was intended and built for. It has done trackdays, drag days, even competed in ten of the best were it got 4th in handling, 8th in top speed run and 9th in 1/4 mile, in rear wheel drive class, and one of the few cars running FULL road spec and standard interior. It has also done countless uk roadtrips with mates, misses, even parents and has recently returned from the nurburgring and a 2500 mile trip of europes best driving roads. A stag do kind of trip were i had 2 Ferrari f430,s for company. The Z did very well both on the straights and on the bends, of which there were many. It coped very well with the heat and thin air at altitude and even stole the show in a few towns with the bonnet up.
So, to sum up. Its been a dream car to own, never landed any major bills other than the usual stuff. Always maintained regardless of cost, its been used but not abused.
THE PRICE!!!
Way back in 2008 this car was up for sale on here for £10000. It needed some tlc so i managed to get it for £9000. Its had a recent respray, all new tyres, front brakes, service, nismo cambelt, plugs, all fluids and filters changed on a major service 2000 miles ago.
You can buy this car and drive away straight to a track, the nurburgring, the alps, a show and shine, whatever takes your fancy.
Im looking for offers around £10000, i realise that may seem ambitious and that the money put into cars is rarely retuned on sale.
But like i said, offers around. Phil the mechanic has said he can verify all the work that's gone into the engine and rest of the car as i only got limited actual paper history when i got the car. Didn't bother me as i knew phil from my previous Z ownership.
There it is folks, sorry its a long read, i could, and probably have gone on forever but its been my passion for so long, wanted to be thorough.
Ill put as many pics on as i can but ive got thousands.
any questions/suggestions, let me know.
Danny
07584664141
Sorry to see this thread Danny, Phil also build my car and he's a top notch mechanic and the engine will no doubt be very solid.
Good luck with the sale mate
Membership No 0780
INSURANCE GOOFA
Cheers fir the input guys. In many ways I hope it doesn't sell. But then I'm goosed. Lol. My worry is, I'll never own anything like this again. Oh yeah, and I adore this car. But needs Bloody must.
Danny
A few more pics and some extras that come with the car. A pair of non leather 350z seats. Was going to fit these to save weight over the twin electric heated leather ones that are in. A vented nose panel. sprayed the same colour but no rubbers fitted or mounting hardware. A spare diff, from a 70k km import auto. I was going to fit a quaffe atb to it then fit it to the car. Its been sand blasted and sprayed in gray primer.
Appreciate I may have to be patient with this sale, but if anyone is interested pm me or get in touch. Ill listen to sensible offers. Before I either, A, go under or B, loose my nerve, keep it and then go under anyway.
danny
Provisionally sold. To a genuine car mad gentleman. He's joined the club and the cars going to him next week. Says it will remain in the club and may attend some meets.
Still can't belive is actually going. But at least I'll be able to check up on it.
So coming to totb and will still come to some shows. But that will be in the legnum daily runner.
Cheers fir everything over the years guys. Been an amazing adventure. Going to do a proper tribute thread/album before it goes aswel.
Thanks again all.
Danny
Actually gone now. Took it to its new home last night. Adam ( the new owner is very happy with it and will look after it well) was a lot harder than I thought to hand over the keys. And for once, the traffic on the M6 wouldn't last long enough on the way down.
Thread can now be closed please.
Going to do a photo album and story when I get time.
Danny
