Left Hand POD for Air Con & Wiper control unit
it depends on what condition you want it in...most second had ones have the screw logs/thread at the top (for the hazard switch) damaged or the screw holes at the bottom cracked..
I've got a couple at home and can send you some pics.. would only want to cover postage & packing.
always get good pics before you buy...
if you can afford it get new ones from Z centre..
Some pics would be great if you don't mind........mine is cracked on the outside and both top screw mounts knackered....will also check out the Z Centre...many thanks
Gary
[sIGPIC][/sIGPIC] "Exaggeration is the enemy of credibility"
Hey Gary
these are the ones I've got... two for the left side (air-con, hazard)
both are good outside and underneath but the hazard screw holes are totally gone on one and will need a bit of rubber hose extension on the other..
showing all three I've got but one is for the right side.
the one in the middle is best..
you can have it for cover of posting and packing.. should be around a fiver.. (if you want it)
Many thanks for looking these out for me....can I take the one with the best Hazard warning mounting points please (the one on the right?) as I can address the lower hole damage more easily....please PM me with your payment details.
Gary
sorry Gary the one on the right is for the right hand side... not the hazard switch one.. (as i said above only two of them are for the left side) i know it might confuse and stupidly still included it... Doh.. lol...
I used a bit of air hose to bring the broken bits out to the correct distance for the hazard switch... or you could cut the good ones off the right side one and heat weld or glue them in to the hazard one...
I'll leave it up to you..
cheers,
Gerry.
Gerry...not your fault!...I did read that... and then completely forgot :blink:
I'll take the one you recommend...please PM with your payment details.
Gary
